My shapeoko was working fine the other day, now when i try to zero in carbide motion, it acts like it is zeroing out, but when i start the project it moves up to the right corner instead of the correct path.
What do i do to fix this? Ive already unplugged and restarted the program to no luck.
Are you using Carbide Motion 3 or 4?
Does the machine home properly?
Can you jog the machine in both directions on each axis?
Carbide motion 3 I believe. Homing works fine. All the movements on the job tab work fine
Is this a new machine with Grbl 1.1 on it? If so, please update to Carbide Motion 4
If it’s an older machine with Grbl 0.9, then CM3 is fine — please describe step-by-step:
- what you did
- what you expected
- what actually happened
and we’ll do our best to help.
It may help to refresh the settings per: https://docs.carbide3d.com/software-faq/shapeoko-3-default-grbl-settings/
I just uploaded to carbide 4. Still having the same issue.
Step by step:
- Connect cutter
- Load job file
- Move to jog - go through homing sequence
- Rapid position to center
- Move to exact starting location
- Hit Run
Then it moves to some random position in the top right, instead of the zeroed location. I just used this on Thursday with no issued
In your step by step, you never mention setting your zero. Did you set your work zero?
