Hi I was wondering if someone might be able to help. I am very new and recently purchased shapeoko xxl.
I am trying to make the shiplap design for the backing of an ornament and not sure how to create that on carbide create. Any suggestions would be greatly appreciated.
Need more input! OK, I get that the “shiplap” detail is going to be a really tiny groove of some sort.
Do you want to cut this from one solid workpiece? Or glue the rim & lettering to another piece?
Do you want the edges of the rim & text vertical? Or is a tapered/beveled edge OK?
However you cut the tiny grooves, you’ll want to make sure your cutter doesn’t gouge the rim & letters. So you’ll likely need to trim the ends to avoid interfering. But otherwise it could be a simple as 6 straight lines trimmed outside of the lettering & inside the rim. With a contour cut using the appropriate depth.
