Simple operations, larger wood in search of better MRR
I’m currently working on routing out pockets in 4x4 lumber for a 2x4. Pocket depth is 1.5" and width is 3.5". I have the default trim router on my SO5 running .1" DOC and 1/8 stepover on a 201 cutter. Even with ganging up 4 boards and 150% override from standard feeds it still takes ~2 hours of cut time for 2 pockets. Wood is Home Depot standard 4x4 pine posts.
Of course I could do these pockets on the table saw, but where is the fun in that? :slight_smile: I’d love to get higher MRR (material removal rate) out of this while staying within safety limits.
Looking for feedback from the folks out there for speeding up roughing operations:
  1. Increase DOC
  2. Keep increasing the feed rate
  3. Use a different cutter? McFly the pocket
  4. Pony up for the ER20 spindle and go from 1/4 to 1/2" cutters
  5. Other?
You may want to look at bits that are designed to remove material quicker such as the Hog and the Beast from IDC or the Golden Boy from CIC.
Ignore defaults.
You should get a two flute carbide cutter
On the 4x4, with a .25 in bit I usually go 180-200 IPM at .25 DoC. Obviously test this before doing a high value project. And that is at full slotting cuts. If it’s not slotting, you can probably get away going a bit past .25in DoC at a full 200ipm.
I can’t help you with the setting for the trim router.
I canTell you with an 80mm spindle I wouldn’t hesitate for a second to use 275 ipm and 1/2” doc with a 2 flute 1/4” bit.
I would start at 200 ipm 1/4” doc with a 1 inch two flute bit.
My Milwaukee 5625 router will pretty easily do an inch DOC in that kind of wood with a half inch bit. I’d make a template (on the CNC, why not?) and be done with the job in a couple minutes. I know when you’ve got a really cool hammer every job looks like a nail, but resist the temptation. A trim router isn’t the right tool for the job.
I haven’t tried pushing the 2.2 kw spindle, but given the propensity of my S5P to skip steps when there is resistance to its movement I wouldn’t think it will take very aggressive bites even if the spindle is capable of it.
I would agree with this recommendation as I’ve got the Beast & Hog bits… They truly do chew wood & spit chips!
Ack. Bits first, spindle second. In the meantime I’ll play with increasing the DOC for the 201 bit and see what happens. Thanks for the great suggestions!
Can you add collets into the mix?
8mm (or 5/16") tooling has the potential to be quite a bit more rigid with the attendant advantages.
Curious option. I initially goofed up and got the 8mm McFly with the result of buying a Haas 8mm ER-11 collet :slight_smile: Agreed that it would be possible to step up from 1/4 to 8mm bits with my current setup
Any suggestions on sources for 8mm bits ?
I have to say that there are are lots of wood specialty tool stores, but I can’t beat Carbide3D and Haas tooling for general purpose items. Haas tooling really stepped up their game with pricing and shipping. Now I just need to 3d print more gridfinity or shaller bins to organize the bits
