Simple stackable box with plans
Thought I would share as I just wanted a simple CNC box that you cut and glue, and I wanted to use Carbide Create. I use a 60 V for the text but you can delete this. Otherwise, just a single 1/4 flat cutter 201 does the whole thing, and no complicated set up or clamping
rabbet box.c2d (995.5 KB)
Picture here:
I’m suggesting that you only need those interlocking tabs on the smaller end pieces to get the same stacking effect. As long as your bottom piece is notched to match. :smiley:
I like the simplicity of your box. +1
