Simulation is long
With the newest version I have, 778, My big project take a long time to show in the simulation.
Any tips to go directly to the end and not watch the full process?
Click on the “Fast-forward” button:
With a big file, even If I click it, it is still showing me all step by all bits, it’s just going faster. My goal is to see only the final result
The fast-forwarded display is about the same speed as it used to take to create the preview without the in-process sneak peek.
If you want faster you’ll want to buy a faster computer.
I have the same issue. Sometimes it go straight to the finished simulation other times it goes through all the steps.???
You can’t currently skip the simulation, but if you un-check “High Resolution Simulation” under the “View” menu the simulation will run a lot faster.
