I was investigating an issue with my X-axis skipping on a couple of cuts when I ran into an issue. I went to initialize the machine and it started making kind of a grinding sound when moving along X and seemed to move the wrong way. Here’s a link to a video showing what happened.
Immediately prior to this, I had been moving the gantry manually trying to see if there were sticking spots or anything I could feel. It seemed to move well with no issues. I had also checked the set screws on the X-axis motor pulley, as well as both the Y-axis pulleys. None of them were loose at all. I’d also checked the V-wheels, which seemed fine - tight but movable with pressure. Lastly, the belts also seem in good shape and not loose.
The skipping only happened twice and the incidents were sporadic. The first was while I was doing a finishing pass with a bowl bit. It was taking off about .01 of material, so should not have been bound in any way. I was watching it and as it moved along the X-axis, it made a “clunk” sound and next thing I know, the machine is cutting through the right side of the bowl. I thought maybe the pulley had caught on some bits of wood so I cleaned everything well and it seemed fine after that for several other projects, and then it skipped again on a much larger cut two days ago. I was in the room but not watching it and I didn’t notice until it was finished.
I’m happy to check other things or provide additional details. I’m hoping someone can help.
I may have figured this out. My v-wheels on the x-axis had quite a bit of gunk in the groove. I cleaned all of them, x and y, and then did a bunch of test jogging, which seemed fine. I ran some small cut jobs and those also went well.
I’m still a little concerned about the grinding and backward movement in the video, but maybe that can also be explained by the dirty wheels?
When I clean and do maintenance on my SO3 I remove my X and Y belts completely. With those out of the way you can move freely move the machine through it’s full range of motion making cleaning, checking, and adjusting V wheel much easier. It also gives you a chance to flip those belts over and give them a good inspection while also checking the belt idler bearings and mounting hardware.
The video I linked showed what happened during an initialization. That was actually the second one. The first one, the router was near the upper left corner. It went up and started to move right to hit the homing switch there like it always does when you initialize, but it started grinding as it moved along the X-axis toward the right side. I turned the machine off, manually moved the gantry and spindle back to where I had them before the first time, powered it on, then initialized again while I took the video. I’ve never seen this happening while running a file and this is the only time I’ve ever seen it during initialization.
The homing switches all seem to work with a manual test. I always set zero to the center of my material by using the jogging controls. I’m not sure what you mean by “extents”, but if you mean was I too close to one edge or the other during a cut, then no. The two times that the X-axis seems to have skipped, the first was on a pretty small piece (12" x 5" or so) that was near the center of the deck. The second one was a larger cut, but also near the center. I’ve had material too far to one side or the other before and Carbide Motion warned me about that, but I never got those warnings for either of the times that the cut skipped.
I will say that I have run a few more cuts after this all happened and they have all run perfectly fine with none of the above problems.
I had another skip happen during a cut. I was in the room but not actively watching and didn’t see or hear it. I noticed when I went to check and saw that the cut was off. I was having it drill holes for a cribbage board and noticed a few of the holes were overlapping and then lines of holes were way off.
After stopping the job, I reset the machine and initialized it. I tried to have it measure a tool and when it came to use the BitSetter, it stuttered trying to move to the right along the X axis toward the BitSetter’s button. Then it just started to lower as it thought it was over the button. I stopped it, reset, and attempted to initialize the machine again, but when it got to the home position, I got an HM008 error. I’ve never seen this before. I tested all of the homing switches and all lights come on with no problems when I touch them with a screwdriver. I used the Settings panel in Carbide Motion to also verify that the software detected that each switch was being used.
Could I have a bad X axis motor? I made sure the v-wheels and belts were clean and free of debris, none of the belts have missing teeth and all seem tensioned fine, I don’t see any crimping in any of the wires and I even disconnected/reconnected all of them to make sure they were seated correctly. The machine will run fine and then randomly skip on some jobs, so I don’t think I can even reproduce it. I’m going to try taking video of a “fake” job with no tool in the machine to see if it happens even with no cutting. I’m not sure what else to check.
Thanks @WillAdams. I’ll pull apart the wiring and check for breaks or other issues.
I did some jogging to see if I could replicate the skipping. I didn’t get the same thing to happen, where the gantry stuttered and jumped, but I did get a different weird noise. It only seems to happen when moving left-to-right along the X axis and I only got it to do it once. Video here.
The usual check for connectors is to power up, wait 20 minutes or so, then check whether any connectors are warm which would indicate a poor connection.
I think that’s it. I’ve had the machine on for a bit sure enough, the connector for the X motor is pretty warm. None of the others are. When I touch/move it, it makes some “electrical” sounds. The connectors are together tightly and the other end is seated into the board. Is that cause for replacing the cable?
Had the same thing happening. Took the X motor off, not only was the toothed pulley caked with debris in the teeth (and i mean packed!), but the set screws had come loose. The pulley would bind on the shaft and give pretty good cuts most of the time, but then loosen up and shift my X zero up to an inch off.
