Slab flattening live edge slab
I need to flatten a slab of live edge walnut. It is 48" long with varying widths.
I have the Shapeoko 5 Pro so I have plenty of room for this. When setting up the program in carbide create which option do I use? Contour or pocket? I have a flattening program for the spoil board. I tried to alter it to do what I wanted but that didn’t work.
Set up a pocket. If you have pro use Raster option. Try to cut with the grain but across would work. Find the lowest spot and set zero there. I put pencil marks all over the surface. Run the job and if there are any pencil marks left run it again. Lower the Z in jog and reset Z zero. Even with an SO5 and a big surfacing bit take a shallow pocket. It takes time but is a lot less stress and will give better results. If your slab is warped be sure to put some shims under the high spots. I use hot glue to hold the shims in place. Hot glue would also secure the piece along the edges. When done some denatured aclohol on the hot glue will make it come loose. I use an acid brush and put a liberal amount on and wait 5-10 minutes and it will peel away. If you use top holding clamps clamps you will have to stop part of the way through and move them to keep the Z from hitting them.
Once you get one side flattened turn it over and rinse and repeat.
A trick to using shims -
Lets say for the sake of example that your rough stock ‘rocks’ diagonally, and that when you push down one corner, the opposite is 1/4" up.
You could just put a 1/4" shim there and the stock is now stable, however, than means you have to remove at least 1/4" on that side to flatten it!
OR, put 2 1/8" shims in, one on each corner. Now the best case is that you only have to remove 1/8" material on that side.
In short, whatever way the slab moves when laying on the table, you are better off supporting it in the middle of its range of motion, rather than at one end of the range of motion.
I use Bondo. I put pieces of 2" tape at strategic points & a blob of bondo on each piece of tape.
Set the stock in place & balance it accordingly. The Bondo also holds it in place quite well.
