Hi all,
For what it is worth, I think I may have narrowed the X-axis drift down to a problem with the Mac OS-X version of Carbide Motion.
I have been battling this X-axis drift, going through a number of failed attempts using different feed rates etc. In one instance I even eyeballed the drift happen while cutting air, after restarting an interrupted cut.
In one case, cutting a raised relief map, I noticed that the accumulated drift during the roughing pass appeared to be zeroed when the finish pass started - resulting in a canyon being cut through all mountains
Here comes the clincher, I was driving the Nomad using Carbide Motion Version 2.0.314, Build Date 2015-04-9 on an Apple Macbook Pro running OS-X Yosemite.
Last weekend I switched to a Windows Computer running Carbide Modion Version 2.0.314, Build Date 2015-04-10. Since then I have already done 3 cuts, none of which has had these X-axis problems. To reconfirm, last night I reverted back to the Macbook, just to see the same problem happen again.
Hence a question, are any of you guys experiencing the X-axis drift using a Windows machine to drive the Nomad? If not, then the culprit may be a bug in the Mac OS-X version of Carbide Motion.
that’s a good question. I’m a Windows-only person, and haven’t seen the issue.
All the problem cuts were using millimetres as unit of measurement in the “Toolpath Parameters” setup window in Meshcam.
So the new hypothesis is: Is the X-axis drift caused by a rounding error somewhere, when converting units of measurement???
(The bulk caps it also wants seem to be already present below the stepper headers).
and would be interested to hear if it works for
