Hi,
Anyone know why the button text is so small, please?
CM is fine…
…as it MS Word…
…so I’m quite sure it’s not the settings on the PC, but then what do I know?
Thanks.
Hi,
CM is fine…
…as it MS Word…
Thanks.
maybe try and play with the “High DPI” options in the file properties ?
As in this thread (for a different problem)
Not exactly the answer, but it led me in the right direction!
The setting I actually changed in the property sheet was the Program DPI rather than the High DPI scaling override (which didn’t work very well):
Thank you
