Small letter cutting
I’m trying to carve out a bunch of names that will outline an initial. It will most likely be epoxied back in so how it looks inside the letter doesn’t matter as long as it outlines well.
I’ve experimented with my 60 deg bit using V-carve but felt like it didn’t perform very well. My text is currently 0.3" tall, I may be able to make it slightly bigger at 0.33" but I don’t have much tolerance to work with as I need the spacing to all fit within my defined space.
I tried using 56125 Amana bit that worked well for 0.5" but was wonder if I’d be better off trying a 30 deg or even a 15 deg V-bit using V-carve?
Or is there something even better that I’m not considering?
For smaller text, a more acute tool will help.
Not sure what you are cutting into, but I would cutout a piece of metal, like brass, and etch the names into the brass.
If you are using a wood substrate, I would cut the initials out of both the wood and the brass and then join them together.
Names/letters this small and smaller work very well with using engraving.
Just my thoughts.
The coins at the bottom are etched into copper coin blanks and have the names of the students from each class year.
Any chance you have access to a laser engraver?
I did something similar recently. All 200 Texas county names surrounding a Padouk inlay of the state. I did this with a previous board and the laser engraved too deep, and this time think it’s a little too light, so I’m sure the third time will be just right :-).
You recommend a 15 or 30 deg?
I do not have a laser, so this wouldn’t be an option for me at the moment
I like this idea ! Current project is using Peruvian walnut
You could use a straight bit and a single line font for the small names, if you can change the font, that is.
I have used 0.0177", 0.0157", 0.0120" 0.0100" and 0.0090" end mills on my SO3 XXL.
Like these:
https://www.ebay.com/itm/152379175878
I’ve had good results using a 90° Vbit to do text at 5mm tall and 1mm deep
Would you do a pocket toolpath?
I dont have a 90 deg but my 60 deg seemed to have bad results, maybe my depth was way too deep and started joining all the curves together so I couldn’t make out the individual letters
A 60° should be fine… create the text apply your size and depth settings then convert to curves. Then use a contour cut and see how it turns out.
Try some testing on a scrap piece of wood and note each with size and depth to see which one comes out the best
Black acrylic and a McEtcher would work, not sure if that fits the art context.
If using a single line font, you would have to do a “follow path” since there is no enclosed perimeter that makes up the letters.
V carve in cherry. Either a 60 degree or a 30 degree vbit- a few years back and no records :roll_eyes:
Cheers.
PS: after looking at this with a magnifying glass, pretty sure this was a 60 degree v bit. The depths are about equal to the widths.
You’ve got this thing crammed into too small a space. Some of the names are split across the middle thing at oddball places, too; someone will point that out.
The main problem is the font choice, because the real problem there, with wood, is the middle of the “e”, “a”, “o” and etc. You’ll be spending a lot of your time glueing stuff into those chipped out places.
That’s why I bought the add-on laser for my machine … small lettering down to 0.1” works for me.
