Plugged my Shapeoko 4 in this morning and the control board started to smoke. Whats the warranty on these things?
I’m afraid that the warranty on Shapeokos is 90 days:
If you haven’t already, please contact support@carbide3d.com and we’ll do our best to work this out with you.
A further note — please check your wiring — usually when a stepper driver chip is blown it’s caused by losing continuity while powered up — please remember to use the operating checklist: http://docs.carbide3d.com/general-faq/machine-operating-checklist/
When you say checking the continuity, do you mean just check that all the connections are stable? Or something else? I understand you check continuity with a multi-meter, but I just want to make sure I’m understanding what you’re implying correctly.
Ideally check continuity with a multi-meter. If you don’t have one, then a visual inspection will hopefully suffice.
