When in Node Edit mode, I have been able to snap nodes to other nodes in the past. I must have bumped a setting I cannot find. How can I snap nodes to nodes again?
No, when node editing, it does not snap to nodes — it does snap to grid points, so positioning things so that the desired position will be at a grid intersection is a work-around.
I definitely used to be able to snap to other nodes in CC, was this feature removed? Is it available in the pro version of the software?
No. It’s never been possible to snap to nodes while Node Editing in Carbide Create.
It works to snap to nodes for other functions.
Is it possible to add it as a feature? This would be very helpful. I have wanted this for a long time.
I was probably thinking of the node snap in poly line. But regardless, I really wish I could snap nodes to other nodes in node edit. <3
Yes, creating the curves you can snap to nodes, but editing you can’t. I usually just zoom way in to get it really close.
Snap to node would be nice when editing. And a toggle to turn Snap to Node on/off would be really cool.
