Hi everyone,
I’m looking to bolt my SO 3XXL to a cart/rolling table, but I have no idea what the size or thread pitch is for the levelling feet attachment points on the frame. Does anyone have any idea?
Hi everyone,
hello Chris
one way would be to take one out
go to Lowes (with in 5 minutes of my shop)
find a nut that would fit and go with it.
Jim
Hi Jim,
Unfortunately, because I got the machine 2nd hand, I don’t have any to take. That was my first thought, I figure it’s approx. 6mm diameter, but just trying to figure out the tread.
Did you email support?
Do you know for a fact your table is dead flat? It’s possible you could tweak the geometry of the bed when bolting down. Something to think about.
They are M8 on an XL or XXL — the feet are available here:
Note that you should not fasten the machine hardly to anything which is not flatter/squarer than the machine structure — when I secured my SO3 on a cart, I put a layer of foam in-between so as to take up any unevenness, and only tightened enough to hold things in place, but making sure the machine’s base wasn’t torqued out of square/flat.
