Not aware of pulleys w/ a matching flat. They’d be expensive / time r consuming to make.
Alternately a key way would work.
Yes it is. I cut a few more test squares with accurate, repeatable results (at least the few I tried late last night). Time will tell if these settings hold and if I have truly rectified the problem.
I did recalibrate first with the 24" ruler, then I dialed it in further using the test squares. This may or may not be the best way to do it, but it is working so far. The ruler, while gives a better overall large measurement, is pretty course in it’s accuracy. I then cut some squares in the 2", 3" and 4" size to further dial it in using digital calipers. I can only go up to 8" with my calipers.
Again, thanks for spoon-feeding me on this one
Great! Pass the favor on to the next one in need. We have all been there at some point.
Good enough at this size! Not sure how it will fare at a larger size, but this is a home-run as far as I am concerned.
Just wanted to add my thank you to all of those whom contributed to this thread. I had the same issue and traced it to a loose pulley on the X axis. I have a 4pro and the stepper motors have a flat spot, however the set screws where not aligned with it at all. Out of sight, out of mind. Thank you again for helping me fix this.
