@CopperTopWoodShop said that roughing was fine so I left it alone and simply reduced the depth to ensure quality.
I’m still quite new to CNC so I don’t really know how to trust my ears yet.
AWESOME COMMENT!
When I teach feeds and speeds I do a class on sound and feel, how to detect chatter. Eventually I have students able to dive for a pause or E-Stop by sound or touching a mill within seconds. I comes with practice, so keep it up! That is a very good skill to develop!
75IPM @ 0.04" depth (0.125" end mill, 2 flutes) on the Nomad is definitely doable in hardwood… depending on your definition of hardwood and certainly only for hogging (severe roughing). You’re correct, it’s “right on the edge” with things like Poplar and Red Oak - FOUND NEAR ME.
I must admit that I forgot that I run with coated end mills and that causes a gain of 5-10 IPM over uncoated. Sorry about that!
At 0.04" depth (0.125" end mill, 2 flutes, uncoated), something around 35-50 IPM is much safer for roughing hardwoods on the Nomad.
Feeds and speeds for wood taken off the internet are extremely dangerous as wood density, hardness and knot concentration and other factors vary widely across the US and the world. Yes, specific woods generally fall into “bands” but not knowing a source and testing it can be quite a surprise.
Quercus Alba - American Oak from the NE - is very different to machine than Quercus Laevis- American Oak from the SE and Quercus Robur from Europe. American Oak from Oklahoma is different than Tennessee.
Red Oak is softer than many other Oaks. It’s common in Home Depot and Lowe’s in the US.
They taste different too! I teach Whisky tasting and, yes, the cask wood is noticeable (Quercus Alba is often associated with Bourbon; Quercus Alba and Quercus Robur are often associated with Scotch).
Yellow Pine is a hardware, not a common, easy to cut pine. I’ve seen this cause a tool breakage more than one. It’s only pine…
Always run a few experiments when getting in a new stock of wood. I recommend cutting chevrons (so one gets linear and curves) with at least 1-2" for each side of the chevron.
mark
