Like so many others, I am having issues with the weak z-axis plate when cutting metals. I have completely torn the machine apart and reassembled it with socket wrenches, and wow did this make a big difference. However, the Z-axis plate bending is now the weak point. It simply just bends and does not have enough support.
Although I have seen some mods out there on ways people are addressing this. Before I start drilling holes in my Zaxis plate I was wondering if Carbide3d will be addressing this as an upgrade of some sort in the future?
You can buy some steel or aluminium square bar and bolt that either side of the spindle mount. Use countersink heads to prevent interference with the z axis rails.
It makes a huge difference and will be just as good if not better than upgraded bent metal plate!
