Two days ago, I cut a PVC fence system into my spoil board. Had zero problems. Cut great. 1.55 x .50 bore with a chamfered edge. Came out great. Happy with the results And finally ready to start cutting jobs.
Went to a job for a friend today. Simple advanced V carve and every bit is shuddering / chattering. Especially on radius’s.
I tested different tooling. Different feeds and speeds. And node edited the design. I even made several other test cuts and it continues to happen.
The original file was created in aspire. Same as my fence system. I exported The vectors Carbide create to see if that was the problem and it still keeps happening.
It will do a fast straight, cut, clean, then slow down like it’s being incrementally jogged.
I’m at a loss here. Has anyone experienced anything like this?
This is with the S05 and the 2.2 KW Spindle.
Has anyone experienced this?
Here’s some video
And the dot C2D File I used for more test cuts
Test cutss with Carbide Motion.c2d (88 KB)
I would upload The aspire file, but it won’t allow me.
Any help would be appreciated.
Also a picture of the fence system it cut just fine.
Seems like I’ve had very bad luck with this machine. I’ll get it set up and be able to run a single file correctly and then the next time I go and use it there’s some problem.
Any help would be much appreciated
