Hey Folks! I recently picked up a Yonico 3/16 bit (1/4 shank) for my Shapeoko and I’m wondering if any of you have recommendations on things such as feeds and speeds for me to input into Carbide Create. I’m looking to use it as a bit that would be faster than a 1/8th but more detailed than a 1/4. Any thoughts?
If you select a tool before clicking on “Add Tool” the selected tool will be used as a template for the new one.
Toolpath
Edit Library
Add Tool
double-click on the new tool to go into edit mode
edit as needed
Ok
close window
The old (316) method isn’t compatible with the new (400 and later) method, and unfortunately custom tools from 316 are not directly imported into newer versions.
In the newer version in order to enter a custom tool it is necessary to create a new user library — tools may then be added to that by using the graphical interface.
See:
For advanced users it is an option to manually edit the underlying .csv file. Go to Help | About | Open Data Directory, then open the Carbide Create directory and find a carbidecreate/tools directory — custom tools are stored in that in .csv files and may be backed up or saved or transferred to another computer, or edited using a text editor or spreadsheet (if one saves as CSV format). See
Naturally, if you have any difficulties with this, please let us know at support@carbide3d.com — did you consider a 3/16" collet and less expensive endmill?
There’s nothing in here about a 3/16 bit. I’m confused. The bit I have is as 1/4 shaft, but 3/16 cutting head. I’m looking for the proper feeds and speeds to input.
I think they are trying to tell you how to add a new tool. I was confused about how to add a tool. But I think you have a two part question and the second part is “What would be the F&S for a 3/16 bit”. This can be answered with Julien’s ebook:
Take a look. There is no one answer because there are a lot of variables in what material and so and so forth. Check out his Ebook and it should help determine F&S.
