Specs for New Computer
So Windows 10 is no longer supported by Windows and my computer cannot upgrade. Buying a new computer what are the specs that I should look at? Not too long ago we discussed the fact that my computer didn’t create tool paths very fast and there were some good discussion about that. Take that into consideration. Thoughts?
I’m on Mac’s, not sure I can help with Windows machines Gary.
Unfortunately, it’s sort of a terrible time to buy a new computer - DDR5 RAM prices are just ridiculous. I just found out that the 64GB DDR5 RAM upgrade I made to my laptop about a year ago is now worth a few hundred dollars more than what I originally paid for the laptop(~$1,300CA).
If possible, find a ‘new’ computer that uses DDR4 RAM - it’s plenty fast enough for use with CAD/CAM. I believe most any recent(3-4yrs) Intel/AMD CPU is plenty fast enough - having a dedicated GPU can make the 3D model rendering run more smoothly though it’s probably not a deal-breaker. I have found my ASUS laptop with it’s AMD Ryzen 9 8-core processor & integrated Radeon780M GPU does rather well. I don’t know if CC works significantly better with higher core-count CPU’s - perhaps the C3D team can chime in on that.
Anything which meets the system requirements should work well:
Windows:
  • Windows 10 or 11, 64-bit (Intel or AMD)
  • 8GB RAM
  • Screen Display: 1280 x 1024
One notable consideration is how screen size and scaling interact — if one has a very high resolution display which based on its size wants to be run at say 200% scaling, then one will want a 2560 x 2048 pixel resolution.
Other considerations:
  • rugged/fanless/sealed — these are nice attributes if one will be running Carbide Motion in a shop environment
  • touch — some folks manage well with this and it makes the interface quite interactive, esp. when scaled up suitably
  • stylus — I like one for drawing, but seem to be something of an outlier
  • tablet form-factor — this can be convenient for mounting on an arm esp. w/ touch
Lastly, one or two devices — some folks get an inexpensive device for Motion, while having a nicer computer for Create.
This is not (yet) really the case. Windows 10 is still getting security updates, you just have to sign up (for free!) do get them, and support runs until Oct 2027.
They SAY support has ended, but that’s just so people think they have no option but move off Windows 10. With ESU (Extended Security Updates), there’s absolutely no reason you can’t just stay on Windows 10.
I signed up, enrolled, then logged out of my MS account, my machine is still getting updates.
Great info! Thanks for the inside scoop. I’ll milk this one as long as possible.
Microsoft seems to be in serious trouble. Security issues have the US government rethinking MS. Linux is great but only if you run a windows simulator or can find native Linux applications. Mac’s are good machines but tie you to their environment. Windows does too but you can kind of get around their One Drive and other traps they have. All computers no matter what OS they run come with a lot of bloat ware. Unnecessary apps that slow down your computer and try to get you into their eco system.
I have worked on computers since DOS and have worked with every OS out there. Windows 1-11, Linux, Solaris, NEXT… So I have been around the block and am still on Windows 11 with an I7 processor. Almost all computers come with solid state drives now and make sure it is a solid state drive. About a year ago a Windows update was destroying certain solid state hard drives and luckily mine was not one of them. However all OS’s periodically mess up and you had better have a good backup on at least 3 places. Online spaces can be one but dont rely on just that because if you loose access to your account there is no recovery from MS or google. A sad state for modern computers but there is really no alternative unless you want to go off grid and turn your screens off. That might be a happier experience in the end.
If the PC is for running Carbide motion only, you can use cheaper HW.
Can you upgrade the current PC to Win11 ?
No…I run both CC and CM on it.
I buy mid range Dell gaming laptops with at least 16gb of memory and a Nvidia GPU.
Good for any design app .
The price of anything with RAM - phones, laptops - has skyrocketed the past 12 months because of the AI craze. It’s another hidden collateral damage cost of “Free” AI tools like higher water and electric costs. Last year when I setup the CNC I punted on buying a new dedicated laptop for it. I too went for the Windows 10 ESU planning to buy one during 2026 holiday sales. Now I’m kicking myself.
End of the year is when I find the best deals.
Given your slow toolpath calculations, I would prioritize a recent Intel or AMD processor, 32GB RAM, and a 1TB NVMe SSD with Windows 11. The Dell Pro Tower Plus is worth considering in that configuration. Check the exact CPU before buying and ask Carbide support to review a slow project file to help confirm whether hardware is the bottleneck.
Did you already try to update or just read an MS warning? I’ve updated a handful of laptop already that MS said “didn’t meet the requirements”.
I had a backup plan so I took the risk of just installing 11.
You can use RUFUS to update your computer to windows 11 if the problem is that Microsoft says your hardware can’t handle 11. I have used it to update several computers at this point. It is slightly complicated, but if you can run a CNC router, you can handle it. Also, craigslist and Facebook market place are great avenues to find used computers. One man’s garbage you know.
I tried a few different ways. I don’t mind running windows 10 but these days I’m always concerned about security. :warning:
Good lord I wish that were the case. Every org/agency I talk to seems to be like “but what if we did Microsoft more?”
I upgraded my old laptop to Windows 11 using FlyOOBE. see https://www.youtube.com/watch?v=XlkdMUEzRbE It runs Carbide Motion.
I had the same dilemma in my shop. I use Vectrix Aspire for design and gcode generation so I could not just abandon windows completely. I solved it by switching to Linux (kubuntu 26.04 LTS). Grok was a tremendous help in debugging wine-staging to run Aspire. I now use gSender to control the Shapeoko Pro. While this is not a complete divorce from Windows like Winboat or some Docker setups it does allow me to run W10/Aspire offline without the usual Windows overhead/reporting. I am not concerned about security updates because it only runs when I use Aspire and then in its own sandbox so it’s not exposed when not in use. So, why do this. Under Satya Nadella Microsoft is no longer an OS developer. It is a subscription services provider using Windows only as a services platform. As I have no intention to subscribe to services to run my shop the change made perfect sense.
thanks!..It took a few tries but I got RUFUS to upgrade a 2011 Intel i5 Dell enterprise laptop The backup to my backup. I had to turn off download updates during the install it kept hanging there. Now to find the "Awful things to turn off immediately in Windows 11 " guide again.
