Speed settings Carbide Create
Hi there,
I’m wondering what setting i should use when routing birch plywood. The choices we have are hardwood or softwood settings (Feed related), anybody any ideas on this topic? now i’ve been using the hardwood option but when making large amount of cuts this is starting to be time consuming. As i live in a part of the world where it’s hard to get router bits other than from abroad i’m hesitant to use the softwood option, because i can’t afford to break my bit.
best regards Roger
I recently used the hardwood settings for cutting Baltic Birch plywood — they’re conservative, but a good starting point.
