I’d also start with shallow DoC and let your ears tell you if the cutter and machine are happy. Taking even just 1mm depth passes and slowly increasing depth of cut or the feed rate will let you hear when the machine gets unhappy. It’s quite easy to clog up or snap a cutter that small, suction or air blast to blow the chips out would also be your friend.
