I’m waiting for my 65 mm VFD spindle to arrive because I burned out the the Carbide Compact Router.
In the meantime, I’m getting ready to cut a plaque out of hard maple. The majority of the cutting will be done with a 45 degree v bit. I’m always confused when it comes to feed, speed, and depth of cuts on a single pass. I have no issues with poplar, pine, MDF, cherry and alike.
I know hard maple is extremely hard for the bit and spindle. My question is where should I be with speed and speed, I understand that too fast feed and speed will bog the spindle down and possibly break the bit. I understand that too slow will cause wood burning. Should I just stick with the Carbide settings to be on the safe side or can I go up a little not as much as doubling the default settings.
I appreciate the advice.
