After zeroing the job starting point, I Load the job file and am prompted to load the proper cutter. Problem is, the spindle is not retracting up so that the spindle can be turned on. I tried a different file and it is retracting properly for it. Any ideas?
Solved. I must have saved the gcode with a zero retract height.
