Spindle Pause after bitsetting to add dust boot
I recently changed from a makita palm router to the 65mm spindle and changed the carbide motion setting to show I have a spindle. Now, I dont get a pause after tool height check to put on the dust boot. I know when set to router, motion would do that pause just to tell the user to set the dial correctly and turn on the router. It is here that I would also add the dust boot.
Seems to me like this is a very simple stupid code change in Carbide Motion to do the exact same for a spindle. Just sort of a last second “hey user, are you ready?” so that it gives everyone a last chance to check their wood piece, clear anything out of the way, AND PUT ON THE DAMN DUST BOOT!
C’mon Carbide - make this stuff a little more user friendly please!
There are probably 5 other things that can be done with easy coding to make this software a ton more user friendly.
I imagine if you setup your carbide motion software, like you do when your machine is new, it should correct this issue.
My 5Pro had the 65mm spindle from day one and it always pauses after the height set.
I have updated and re-setup the motion software several times.
Always pauses.
Just my guess.
Are you using the “Carbide 3D Shapeoko” post?
Put this post in your …AppData\Local\Carbide 3D\Carbide Create\posts folder & give it a try.
I had previously added a pause “M0” to let the spindle rev up, so I just moved it to the toolchange.
Carbide 3D Shapeoko pause.tap (5.4 KB)
Rename .tap to .post
Note that using a custom post-processor requires Carbide Create Pro and going to the trouble of writing out a separate G-code file, as opposed to using the in-built post-processor which is the default.
What about for us Fusion 360 users?
Folks using other tools which require writing out G-code are able to set up their post-processor to output whatever G-code they wish.
I have a spindle. I always add the dust boot after changing the tool, but before the measurement.
It has worked flawlessly every time. The dust boot does not interfere with the BitSetter.
EDIT: So, yeah, another pause after the measurement would be incredibly annoying. If for some reason it gets added, make sure there is a way to turn it off.
What Michael said! Mount the tool, then the dust boot, measure off the bitsetter and into cutting.
So you never forgot to push the spindle on button and never broke a bit because it went to cut with no spinning??
Bet you wish you had that last pause before spindle on and cut…
