Our local library has a Carbide 3D Nomad. During my first test run, I noticed that the spindle is cutting to the far right - off of the base. (See video).
My setup:
I created a test model in Autodesk Inventor (TestModel1.stl (2.1 MB)
Lastly, I zero’d the machine at the bottom, left corner of the stock 8" x 8" x 1" that I was expecting to cut if the air test run would have been successfull. .
I tried changing settings and retrying with no luck. Can anyone provide some helpful advice?
Thanks for checking. I will have to get the MeshCam file the next time I visit the library. IDK. I set zero to the bottom left of a 8" x 8" x 1" stock, so there should be a far right movement in the beginning. Btw, I added a video of the spindle moving off of the platform to my original post. Here it is again.
I went back to the library and recreated the MeshCAM file from the STL file. I reran the g-code and the movement looks correct now. I guess it was user error. I’m still not sure. Anyway thanks for your response.
