After buying my first Vee cutter I noticed I have vibration in my spindle. I can see from running my cutter on low and looking at it from the side that the v cutter tip is spinning off center. Anyone know what might cause this issue?
I cleaned my collet of dust and tried retightening multiple times with no luck. Even tried a few different tools.
Unfortunately I only had the option to buy the new standard Shapeoko router. And I’m running the standard collet that came with it. But I do have the armada tool 60° vee cutter from tools today. That’s what I noticed the issue with.
Just as an update, I emailed support and they said it’s a bad bearing. First they’ve seen on this router but happens the same with the other brands. They told me to dispose of the one I have now and they will be sending me a replacement ASAP.
Pretty impressed by the service from Shapeoko so far. Of the two times I’ve dealt with them (missing screws for mounting my waste board, now this) they were quick to react and sent free replacements right away.
