Spindle weight issue?
Continuing the discussion from Homing error issues:
So I did quite a bit of trouble shooting. The homing sensors are fine, all that jazz. I took the spindle out and everything initialized smoothly. I put the spindle back in and boom same homing error. Is there an issue with the weight of the spindle maybe? Or even the z-axis? I performed the removal and replacement experiment a few times to test my hypothesis and that is the common denominator. I however am unsure of how to rectify this haha any help from anyone would be great.
Which spindle do you have?
Are your linear blocks well lubricated?
I have the vfd spindle kit that I purchased from the site. I thought maybe it could be a lubricant issue initially but rollers are lubed up. Are you referring to the flat metal pieces that it rests on and slides across?
Please contact the folks at support@carbide3d.com and we’ll have someone work through this with you there.
Thanks Will. Should I just copy and paste my previous questions?
Yes, any information will help.
