I started to surface my spoilboard (2x4) the other day and saw that three of the boards were split (delaminating?) there were three of the boards like this, the right and left most boards and one toward the middle. The boards were splitting on both ends and when I took them up today, I saw thst the split was only on the ends; it did not run the length of the board.
I was already thinking about new waste boards so no great loss but wondered what might have caused this. Over tightening the bolts? Probably not moisture; this is Lubbock Texas after all.
MDF is a fickle mistress. The factory surface is quite hard but after surfacing it is pretty soft and bumpy. The last time I surfaced my spoilboard I sanded it to 120 to smooth it out. Some people seal with shellac or another type of penetrating finish. If you do seal it I would seal up all 4 sides. I have been to Lubbock and it is dry as a bone. However when it rains things are so dry the humidity goes up and things like MDF soak it up. Then things dry out again. That causes the MDF to swell and shrink and that may have caused your cracks. MDF has no laminations like plywood because it is basically sawdust and glue.
I hadn’t thought about the surface of MDF being denser than the interior. I use a lot of Total Boat Penetrating Epoxy. I might put some on one of the old boards to see the effect.
To tell the truth, I just got the new boards installed and I’m probably not going to remove them to seal them. Maybe next time.
