I haven’t used my SPro in several months. I just tried to fire it up, with no luck. The power supply is delivering 24V on both sets of pins. The controller is dark and unresponsive. Is there a typical ‘go-to’ on the board? How about a schematic, where would I find that for a V3.0C board?
We haven’t published a schematic for the any of our boards — there are some annotated images for older boards available from support, and of course the Stepoko was fully documented on Github, but there isn’t anything for the new v3 and later boards beyond the silkscreen — there really aren’t any user-repairable components beyond the USB connector possibly.
Did you also switch on the power at the front panel of the controller?
If you’re w/in warranty (12 months), let us know at support@carbide3d.com — if not, we have replacements on a hidden page in our shop:
(be sure to choose Shapeoko 4/Pro from the drop-down for $120)
William. Thank you for your quick reply. I’m glad you mentioned the front panel power switch. There was a pin pushed out of the connector. Problem solved! Thank you so much for the tip where to look. Have a good weekend.
