I don’t think that this has been mentioned here (a search didn’t turn it up) so I don’t know where I saw it mentioned.
https://mesh2solid.thavision.com is an online utility for converting faceted STL files to CAD-friendly STEP files. I ran a couple of knife scale STL’s through it last night and am really impressed with the results. The scales are not that complicated–constant-thickness, contoured edges, spotfaced holes for the fixing screws–and the only thing that mesh2solid didn’t do very cleanly were filleted edges. But for my use that is a non-issue.
STEP allows for a facetted representation versus a surface or solid representation.
The fact that fillets were an issue is not surprising.
I would guess the STL file showed the same fillet issue.
There was a bit of discussion of this on Hackernews recently — apparently one of the reasons the STEP file format is so complex is because it allows the inclusion of tessellated triangle geometry such as one would find in an STL.
Moreover, there doesn’t seem to be a robust mathematical solution for determining the optimal geometric representation of an arbitrary set of tessellated triangles.
STEP will handle Parasolids type surface and solid representations.
A faceted model would have to go through a surface conversion then solid conversion if needed.
If the conversion can determine a smooth surface ( has enough triangles ) then you would get a smooth and scalable model.
This type of conversion cost $ and compute resources as far as I have found.
I would love to be wrong.
