I don’t know if this affects anyone else but I currently have a project with components that need to have different origin points (X zero Y Zero). Mostly tis relates to workholding. I would like to able to recall them. Currently I just move a known amount and remember it myself, but my memory has its bad days…
I would be good if I could store and call up previous origin points.
Thanks,
John
Click on the Position Header in Carbide Motion to switch to Machine Coordinates, then write those down and when necessary use the MDI to get back to those coordinates to set zero there again.
Then, you can set up a Quick Action for each to move there and set zero.
