For those of you using products in Vectric family this video from Kyle Ely has a great tip. Most of his stuff is super helpful.
I traced some images and most of the lines really needed to be horizontal and vertical but of course came in all janky. Using this method I was able to clean up pretty quickly.
I don’t know if CC has equivalent capability. If not, maybe it’s something to add to the list.
It’s a really good tip on an impractical example. Why wouldn’t a person draw a rectangle, copy it, then rotate the copy 90 degrees… But your post is accurate. Kyle knows his stuff.
