Wondering if anyone else has experienced this issue. I’ve attached a pic of the model(rhino6) and the milled piece. I’m getting these horizontal artefacts from what seems to be inconsistent Z heights across flat surfaces. Gcode output from Visualmill/RhinoCam. I’ve only started seeing them when doing these smaller items, but that may be due to having the machine for a while now- so if something needs a tighten may also be a cause?
Grateful for any clues here. Pain in the butt micro sanding after the fact.
something is loose, check v-wheels. The carriage can “rock” left and right or front to back, causing this. It must not be a lot, or you would see it all over the piece.
Agreed, lines appear to all be horizontal across the image. Either your material is moving in the z direction, or perhaps your rails have buildup on them causing the wheels to rise and fall.
Final passes were done with .5 and and .3 mm spiral ball upcutters. There was material left from previous pass so these should have cleaned it up. Ive got the full surface of these 5mm thick slices of board held down with double sided kikusui tape. Never had problems previous to my last 2 jobs. The one thing I haven’t tried is a parallel finishing in the y direction to see if I then get vertical lines.
I run the simulation within Rhino and shows it to be clean. I haven’t updated the Carbide motion in a while either, maybe something to do with it?
