Struggling with z Depth of cuts
My z axis cuts seem to be .02" short
I milled acetel as a test to measure.
When i manually raise the spindle it will fall on its own, is this too loose?
It’s difficult to tell what is incorrect calibration, and what is incorrect setup/configuration
Suggest you mill a series of pockets which form steps and measure the height of the steps, then calibrate the belts per: https://docs.carbide3d.com/shapeoko-faq/how-to-calibrate-the-machine-for-belt-stretch/
i will try this,
When i enter the $100 values are they stored permanently or do i need to enter them before every job
They are stored permanently.
