Any suggestions on what bit to use on detail inside a sheriffs star. The project is on 1/4 mdf. I have tried v carve 301 & 302 at 1/8 th. They do ok on some parts but blow out other parts.
The preview looked good. When the program was running the router started over the R and went up and down several times creating that distortion. Same thing on the O.
Seeing what you sent I believe I am doing everything wrong with creating the file. As soon as I get home I am going to try to follow what you sent. This is all new to me and I am trying to learn. Thank you for your reply.
I am following your message step by step and when I align the outer geometry then v carve tool path, it shows the path going from point to point through the entire project.
