When surface planing what cutting category should you use, contour or pocket
pocket
(20 characters)
I just draw the path I want, and use contour / no offset.
I use “Pocket” for clearing out pockets. But for surfacing I don’t like the plunge, which leaves a witness mark on the part, and the fact that it only conventional cuts. I like to to start & end the tool off the part, and climb cut. I also draw my own path & align it with the grain of the wood (on a wood part) so it’s not cutting across the grain.
I am new to Cad/CAM design. How did you create your own tool path?
One way would be to draw the parts, edit as necessary, then stitch together:
First a circle, so one can get a semi-circle:
(it will help to have the grid set up so that things line up/snap nicely)
Node Edit:
right-click:
Cut Vector:
d to delete the current selection (or use the right-click menu):
select the remaining node:
d
Done
Draw in geometry as desired using the Polyline tool:
Done
Select:
copy-paste or Duplicate:
mirror along the vertical axis:
Drag into position:
Select all and copy-paste:
Drag into position:
repeat as desired, then select all:
and Join Vectors to get a single object:
