I use fusion, and the basic 2D facing operation. It takes some fiddling to get it to work on our machine with the interior gantry and a waste board that uses most of the travel up, especially with a large cutter. But you should be able to get it to work if you play with pass extension, stock offset ect. Your mileage will very, based on the size of your surfacing bit and how big your waste board is. Or, just create a sketch on your waste board model, setup the vectors however you wish, taking into account the surfacing mill and step over. Then use Trace. Order the cuts however you wish.
Oooo Middle part is the final surfacing after tramming the spindle head
Check out the difference from the previous on the left/right!
That said, the Pro is pretty deadly right out of the box! Just wanted to dial it in a hair more.
This topic was automatically closed after 10 days. New replies are no longer allowed.
