Export them to SVG (to integrate into other designs) Once exported, in the SVG the hole locations do not match the layout in CC. And if your re-import them to CC, they are still incorrect.
The way I finally set up the fence was make the work area the size you want, put the corner guide in place, make the short fence file twice with the fence in its position and just set zero for the corner and cut your grooves and holes from that referenced point. Takes roughly six minutes.
