Svg from Inkscape in Carbide Create possible incompatibility
Could it be a compatibility problem between specific version of Inkscape and Carbide Create V514? I am using Inkscape 1.0 (4035a4fb49, 2020-05-01).
I just noticed that there is now an Inkscape 1.0.1. I will load that version of Inkscape and see if the problem continues. I will get back to you on the results of the update and test.
Thank you for your patience and time. (SMILE)
