I’m new to the shapeoko community, and had an issue today that I couldn’t seem to figure out.
I imported a pretty simple SVG to cut out: A simple L shaped fence for my threaded spoilboard.
When it cut I noticed that it treated each line segment as a unique path, and cut each side of the part to full depth before proceeding to the next, rather than making a single patch around the part.
I tried grouping the geometry in CC, but the toolpath simulation still shows the same issue.
The part turned out fine but is really inefficient and may pose issues to other geometries in the future.
The entire geometry is in one sketch, outline, holes, pockets, etc.
I’ll try breaking it into different sketches to see if that helps, but I would imagine the conversion to SVG would be the same.
