Hi,
I am looking at using a T Slot router bit to create an undercut section through my design. I have a Shapeoko XL HDZ and the Bitzero and was wondering how I would zero the tool. As I have only previously used a flat end mill with the Bitzero.
This is the tool I have purchased: https://www.amazon.co.uk/gp/product/B07G5ZDR5P?ref=ppx_pt2_dt_b_prod_image
Thanks Jack
Start by probing with a supported endmill, then change to the T slot cutting tool, then re-probe for Z only.
Thank you, will give it a go now!
And remember not to hit pause on the job when the T slot cutter is engaged…
