Anyone know where you can buy the T Track Nuts that come with the Shapeoko Pro. Looks like they take a M6 Button Head Screw
Following - I’m interested in these myself.
These are now in our shop:
I got these, they work great:
Thanks Guys. I’ll some some of these
Finally got the Pro set up for my classroom, and I now see the need for these T-nuts. I was literally just helping a student with a design that uses captive nuts, and I made these as a quick example to give him a better idea. And it will also help with clamping.
Prints without supports, with an easy cleanup. If I make a bunch more, I might remove the top “tube” and print on the side. Regular M6 nut fully inserted. I’m sure it’ll hold for even the most psychotic clampers.
I will get the models on Thingiverse if anyone is interested.
Hi Neil. They look like decent T Track Nuts. Definitely be interested in a Thingiverse link if you’re still willing
@DeadMetal Welcome to the community!
They are decent nuts, thank you.
I’ll see if I can get a link up tonight or sometime soon. In the meantime, here is the STL.
T-nut_soPro.stl (272.2 KB)
Wow, those look great. I am assuming that 1/4-20 hardware no longer works now with the t-tracks?
Untested…
T-nut_soPro_14-20.stl (273.9 KB)
Thanks! Now to find some 3D printable clamps.
I would say mill them (from wood or aluminum) rather than print them?
A clamp needs to be quite rigid, or bad things tend to happen.
Those green ones on the pic are C3D’s fiber-reinforced ones.
I am aware that there are all kinds of fancy 3D filaments nowadays and I am not saying it’s not possible to print good sturdy clamps, but I wonder if it is worth it (when one has a CNC, that is!)
There are a couple of designs at:
https://wiki.shapeoko.com/index.php/Workholding
I tried a couple of different 3D printed designs — they work, but have a lot of flex and give and I came to view them as even more disposable than the wooden or plastic ones which are easily cut out:
Fiber-reinforced? Ah. I thought they were just plastic. Perhaps I’ll try milling a few then. If the t track nuts weren’t so small, I’d probably try milling those too.
