How do you work the tab feature in CCv7, “contour” option in toolpaths?
You put the Tabs where you want them in Design-Edit but you must have a vector already drawn for the option ( a grey square with green tabs on each side) to be present. Then you define the tab size, turn them on/off etc. in Contour.
Do your toolpath and give the dimensions of the tab. Then go to design and select the object. Then go to the tab tool and place your tabs. Save your file.
Thanks guys, much appreciated!!
