Finally broke down and ordered a Mafell Quick Change Spindle:
https://www.timberwolftools.com/mafell-fm-1000-ws-milling-motor
and the recommended step-up/down transformer:
and am wondering if rather than running a separate circuit (if it proves too much for the existing basement wiring) I shouldn’t just tap the dryer outlet which is on the other side of the wall — if I get a splitter:
https://www.amazon.com/Parkworld-886580-Splitter-Receptacle-3-Prong/dp/B07CVSJ6S9
and a 220V-110V adapter:
https://www.amazon.com/Parkworld-61469-Adapter-10-30P-Lighted/dp/B081XXHZPJ
I’d essentially have a dedicated circuit (so long as no one is doing laundry) — even w/ adding an extension cord it seems a lot cheaper than having an electrician do a run from the panel — is there anything I’m missing here?
