During the cnc operation, this screw dropped next to the drill. I found it and immediately stopped working.
I can’t guess where this came from. I ask for your help because it might be dangerous to continue working in this state.
Check the ends of your bearing blocks, it looks like the screw that covers the oiling ports.
Thank you for your precious time. Where are the bearing blocks? Could you mark them in this picture?
Correct.
Look from underneath the Z axis.
Due to the structure, it is difficult to check this daily from below. Can you give me a rough idea of where it is located?
I don’t have a Nomad to take a photo - however, this is a Z axis bearing block (ignore the red seal yours is black). They are between the Z axis plates.
thx! i found it. I had a hard time finding it because it was invisible haha
