Ok, it doesn’t spin, so it’s not exactly spindly:
Another candle holder similar to this one:
Fun what you can do with a little “Shapeoko gone wild”!
Dan
Dan
is that a Co2 laser?
You went with the 7W from J Tech Photonics, yes? What settings were you using? (I can see and hear your air assist, hehe.)
What material are you using? It is very pliable.
Looks like Baltic Birch, or possibly Lauan plywood with a “living hinge” cut into it.
I wish, 7 watt diode
6 passes at 100% 11ipm. This particular plywood is tough to cut for some reason. I can cut 0.118” thick of another brand Baltic birch same settings, this is only 0.063” thick. Air assist is everything.
Baltic birch plywood, only pliable because of the cuts.
Yep! I fell in love with the living hinge design the first time I saw it. I’ve drawn up several in the past to be cut on the SO3 with router, but never tried actually cutting one till I added the laser. This is the first design that worked right and also the simplest, a line with a small circle on each end.
Dan
@DanoInTx What are you using for the CAD work on those designs?
Old school (sort of), drawing 2D vectors in VCarve, exporting as SVG, then CAM in Lightburn. I could do full 3D designs in Catia, but honestly I like working flat. A little math, and a lot of aligning and trimming tiny lines and circles. The most difficult part is waiting for it to cut, then hoping you don’t break it during assembly, but I’ve learned a couple tricks along the way. I’m think my next one may go a little less square, maybe fold the bottom under and puzzle piece the bottom instead of having a separate form glued in place, maybe even build some varying taper into it ![]()
Dan
