There was a time that CM told me to set the Router Speed. I have not had the pop up for quite some time. Fingered it was a glitch.
I think I have everything set correctly.
I think having the bitsetter enabled disables that prompt.
Are you talikig about setting spindle speeds? You can do this with each tool. This is the standard free software that I just downloaded.
Having the BitRunner enabled prevents the speed prompt from showing up, since it’s part of the on/off dialog.
If you disable the BitRunner in Carbide Motion, then you should get the on/off prompts again which include speed settings, and the BitRunner will still turn things on/off — it’s only the prompts which are disabled by that option.
I just set up my BitRunner jobs so that all the tools use the same dial setting.
Thank You all.
20 Characters
