Threaded Spoilboard for SP Pro XL
Hi all - Is there a file for a threaded wasteboard designed to fit on top of a SP Pro XL hybrid board? I’ve seen different boards but not for thr SP Pro XL.
Is this what you are looking for?
S. Pro: Shapeoko 4, Pro, & HDM Fixture Tooling Plate – Saunders Machine Works
S. 5 Pro: Shapeoko 5 Pro Fixture Tooling Plate – Saunders Machine Works
It is modular, so you would pick the number of plates for your cutter size.
I was looking more looking for a file so I can cut it myself. Thanks.
Oops, my bad! Re-reading it you clearly wrote “file”. As I was putting in those links, I kept thinking, “Man, this is going to be expensive for OP…”
Yea, definitely why I want to make my own. Anyone have or can point me to any files?
Not a file but here’s an old video for reference. Shouldn’t be that hard to make your own file using this as an example.
Thank you! To confirm, would a 9mm hole fit a standard m6 bolt?
