i understand what tile is so if your useing the xl then which direction are you going to tile
In most cases, you’d tile along the Y axis.
And what exactly is tile?
It the method of machining things longer than your machine. Here I made (engraved) a 60 inch sign on a machine that has 16 inches of travel:
@Rich Can you explain how you set this up? Are you using Fusion to do this?
Thanks!
