TILING entire sheet of plywood
Hello, Im new to CNC and feeling overwhelmed and intimidated. I purchased the shapeoko pro 5 so I could learn tiling. Is it possible to use an entire sheet of plywood??
The video made it look easy, but it seems unreachable. Advice would be appreciated!
You’ll probably need to remove the BitSetter, and adjust the left/right position just so, and limit the size of the tool you use to cut along the edges, but it works — if you’re having difficulty, upload your file and we will look into this with you.
